Any signs of melting of the wires or burt casings. I wonder if there is a continuty issue in the harness causing the computer to shut down communications. A wiring diagram and schematic would help greatly. With this you can unplug the computer and check the basic wires for voltage, grounds or amperage..... It could be as simple as a wire rubbing the block causing dead shorts. Typically computers are good or bad, not both.
