Originally Posted by
Supra_Comp
Thanks guys. I will definitely need some help along the way! I guess my biggest concern is when I do the engine cradle, I want to make sure I get it spot on to the original height so that the motor is the same. If I am off, I guess I can shim it if required.
I assume the engine cradle should be made of some stout lumber (2x4's, 2x6's) but for the stringers, has anybody used anything other than 3/4" ply? I was thinking of running 1x4's and shaving them to the shape of the hull instead. At least with the boat being a fairly flat hull the stringers are straight runs!
