Here's a cheap one that ends in 22min if you don't mind ordering from Hong Kong:
http://www.ebay.com/itm/9W-MR16-3-3W...50802129229%26
Here is a little better picture of the oxidation damage before we tackled it. I kinda thought the baby blue fade was pretty :D
http://i.imgur.com/gHNPsZA.jpg
Here is the updates. Nothing too exciting.
Pulled the spark plugs. I'm sure they were original because they were filthy. Installed the NGK Vpower plugs.
Installed new impeller. The one I pulled out was in good shape but it is hard to know that before you pull it. Pretty simple job and using the paint can opener was a great trick.
Pulled all the cup holders out. Impossible to get out with out breaking the plastic holders. New stainless holders should be here today. $70 off of Amazon is a pretty good deal.
added ball valves and tee to the fill line on the driver side ballast area.
Can't wait for warmer temps.
Wow, what a difference. Looks like you did a good job on the oxidation gelcoat correction.
HIFLYR,
Was the bulb for the transom a 1156 or 1157? I'm looking at them on the internet and the base is a little different. Lots of choices on Amazon for $5-$10. I'm going to pull it tonight to check. It's pretty easy to tell if you are holding the bulb. The 1156 has one filament where the 1157 will have two filaments.
Mine was a 6Cp it's shorter than an 1156 or 1157 but with the same base.
Darn, the 6cp is harder to find in an LED bulb. Go figure.
This is the LED replacement that should work on your transom nav light:
http://www.ledlight.com/SearchResult...KeyWords=84634
I have a couple of each size in a toolbox. Going to try them out tonight.
Which base do you order? The 1157 and 1156 have different tabs on the sides. one is the same while the other is a little more staggered
http://cresteastcoast.com/Catalog/WP2_Bulbs.pdf
I'm getting too obsessive about these lights! Here is a nice chart with all the different bulbs.
