Originally Posted by
Salty87
i'm fairly certain that none of us want to see someone bust their a$$ for nothing.
i've seen some really crappy glassing jobs by the factory but i don't think i've ever seen a boat with no glass on the stringers. if you're not encapsulating the stringers then i'm not sure what your test proved. you should try bedding a piece to the hull and then standing on that.
the point someone made about it not being structural is relevant. if you're using this stuff for the floor, you'll need more supports than was originally designed. plastic boards may sag between stringers and cross supports...esp if you plan on filling sacs.
what thickness do the boards come in? the main stringers are 1 1/2" thick...will you laminate pieces together?
