Bump for question above.
Attachment 13696Attachment 13697Attachment 13698Attachment 13699 For the throttle I made a bracket & riveted it to the existing throttle mount that is the same length as the carb cable mount. I made a new cable hold mount to line up with the throttle body. There is no need to change anything with the shift cable. If you are serious about doing this I have to tell you it will ,will, will take a lot of time, time, time.. For me making the change to efi was a challenge to see if I could do it. I would not recommend this change to anyone. But Good luck I will help you if I can.
Thanks a bunch for the info and the good pictures
