Originally Posted by
sybrmike
			I'm facing similar issues.  I centered the straightened shaft in the top end of the shaft log as reference when installing my straightened strut.  All seemed fine, but dummy me didn't check the shaft clearance at the bottom of the log until after all the 5200 had set up.  I still have a very slight shaft contact with the gelcoat below the bottom of the shaft log.  It was much worse before with visible wear on the hull and shaft which prompted me to have the shaft and strut straighted in the first place.
I've since gone back with straight edges, dowels, laser levels, etc. & convinced myself that no reasonable amount of shimming at the original factory strut location would allow the log and strut bores to be concentric.  So once again, I don't think Supra used exacting tolerances on these things back in the day.  I'm just going to sand the gelcoat for clearance and keep my fingers crossed when I install and align the engine in the next few weeks.
Good luck & keep us posted on your fix...
