How did you do the foam and how much was the restoration may i ask just curious i have an 1988 comp that was given to me and i need to rebuild the motor the boat is in great shape and i could do the motor this year and the rest later.
the floor was somewhere around $2500. comp should be a good bit cheaper as you don't need as much in materials.
the foam was simple...line the area with the plastic and pour the foam. don't let the foam sit too long or it won't release from the plastic. the foam will set up in mins, peel while it's still warm.
