Originally Posted by
ScottnAz
I must say, I've been very pleased with the upgrade in the 3 months I've been using it. I haven't measured/calculated the GPM, but it is much better than the sprinkler valves, and that's good enough in my book. If I were to do it over, I probably would have added a 2nd thru-hull and separated the rears from center pump, and gone with the 1200's vs. the 8's, although I haven't done the calculations to make sure it would be much more efficient.
Only problem I've been experiencing is surging with my center pump. There are times it won't pump a solid stream of water, it more or less spits and surges. The bag eventually fills, but I need to find the time to look in to the problem.
