After taking the day off from painting the house I decided to work on the 92' Sunsport. Since owning the boat 2 yrs now it has had some steering issues. While under power the boat is very difficult (nearly impossible for the wife) to steer to the left. I always assumed it was the steering cable until a little research on the forum turned up the possibility of a bent rudder.
Low and behold I unhooked the steering cable and felt no resistance. The rudder easily moved in on direction and sort of chattered in the other. Dropped the rudder and found that when placed on a flat surface then end of the shaft touches on one side and when flipped over the shaft is roughly 1/2 inch off the surface. I am thinking the shaft is bend roughly 1/4" side to side?
After viewing the rudder from the side I noticed the rudder shaft does not come out of the rudder at a 90 degree angle. Am I correct to assume the bottom of the rudder is bent backwards as if the boat had struck an object?
Couple questions, should I bring the rudder to a family friend (machinist) and have is straightened out replace the packing rope and reinstall? or should I go new? My understanding is that if I decide to go new I would end up having to by a whole new rudder assembly?
Thanks for the help!
