PCM 454 starter - Saltare
I want to get a new starter for the PCM 454 LH standxard rotation in my '89 Saltare. It is a top mount rear entry starter mounted on the bellhousing and offset to startboard side. Current starter works but occasionally I get a small puff of smoke out of it (internally). Cleaned terminals and no difference. Cranks fast but I don't want it to die on me. Looking at DB electric and going to order a higher output alternator too since they have great prices and several here have used them.
Looking at past threads I see two different starters that different people claim are correct for the boat, but not specified where the starter location is. One is SDR0065 which seems to be for reverse rotation engines as it cross references to PCM# RA122008 and then to this Sierra starter (http://www.marinepartssource.com/new...ured%20Starter) which states:
Top mount rear entry starter
Opposite rotation starter
GM and Ford engines clockwise
The other one mentioned here is #SDR0105 which cross references to PCM# RA122008 and then to this Sierra starter (http://www.marinepartssource.com/new...ured%20Starter) which states:
For Gm and Ford standard rotation engines
Not sure how the SDR0065 would work in a standard rotation engine unless it was mounted in a normal front entry application as it would turn a standard rotation engine backwards in a rear entry? So the SDR0105 should be the correct starter as I have a standard LH rotation engine with a top mount rear entry starter? Please help clarify before I order.
Just make sure to reference true north when installing the starter so it will initialize the start sequence properly...lol
Re: PCM 454 starter - Saltare
Quote:
Originally Posted by
wotan2525
I just wanted to update this thread with my experience with SD0105. I've been running this starter for as along as I can remember (and obviously recommended it in here.) Unfortunately, my luck with this starter was spotty at best. I don't think I have had one make it through 2 seasons. They seem to get REALLY corroded on the inside. Recently I was stuck when the starter would no longer turn over and I had to paddle/swim the boat in. This was a starter that I installed of July 2013 so I only had it for 14-15 months.
This was the DB Electrical version but I suspect most of them come out of the same chinese/mexico factories.
Anyway -- I took the starter apart and was apalled at the poor construction. The armature had some really bad deformities on it (that must have been that way from the factory.) These defects had caused all but 1 brush to be broken, and the brush springs to also have broken off and been chewed up in the field windings.
I decided enough was enough -- I'm done with SD0105!
In all of my other vehicles, I always upgrade the starters to PMGR type starters when I replace them. For some reason, I had not been able to find a PMGR starter suitable for the 454 marine engine. It requires a starter that spins CCW and all of the PMGR CCW starters I could find had a completely different "offset" style of mounting ears.
Finally I've found a solution, though...... and I can't believe how fast and smooth my boat now starts! The LESTER 6793 is a PMGR starter in CCW orientation. It has the same number of teeth and the same mounting ears. For whatever reason, none of the parts lookups specify that this works with the 7.4/454 engine, but I ordered it anyway and can confirm that it works perfectly. Here's the one that I purchased:
http://www.amazon.com/dp/B0094JJK7W/...332200_TE_item and here's the same item at DB Electrical (for those that prefer them):
http://www.dbelectrical.com/p-2299-n...-140-6075.aspx
It's a much smaller, more powerful and more energy efficient starter than the stock one. Swap over to it the next time your starter craps out.
http://i635.photobucket.com/albums/u...psped8drnp.jpg
What are the two purple wires for? I'm guessing this is "plug n play"?
Great write up
