'86 Ts6m... I started 4 years ago, chickened out, ready to dive back in. Need Advice
I bought my "dream boat" several years ago, a Ts6m like the one I had skiied behind when I was a kid. I immediately had the same heartbreak as many of you when I pulled the floor and found rot and waterlog. I pulled the floor, dug out the foam, spooned out the stringers, and started replacing. I recut the stringers from dry pressure treated 2x material, then took it to a local fiberglass guy who built boats for years at Norris Craft in La Follette, TN. He glassed them in beautifully, and had planned to put a floor in it for me later. A month or so later, he got sick... and never recovered. That was when my boat went on eternal hold. Now I have a garage that is plenty big for me to restart my project. Here are the issues from the past that worry me now:
1. I didn't "shore up" the hull when I pulled and replaced the stringers. I understand that this could have adversely affected the hull shape?
2. I didn't split the upper and lower hull... everything in the bow seemed solid, and I was worried that I couldn't put everything back correctly. The stringers were rotted from the drivers seat back, but I was cutting solid wood in front, so I reattached the new stringers to the new wood up front. Mistake?
3. I have some 1/2" marine plywood that I planned to floor with, and was depending on the "new" foam (that I haven't done yet) underneath to ad rigidity to it... after a couple hours of reading what you guys have shared, I'm not sure I want to foam it. I am now considering 3/4' pressure treated plywood without foam.
4. Since I didn't shore up the hull to replace stringers, and didn't replace the wood in the front of the boat, would foam add back rigidity and safety that I may need?
I hope that this boat will give a piece of my childhood to my two boys... but I don't want them to look back in 30 years at Dad's crazy renovation project that's sitting at the bottom of Norris Lake. If items 1 and 2 have sealed the boat's fate, then I will kill it now before going any further. Please share your opinions.
Thanks so much... Great info. Think I'll order the 2 gallon kit of CPES (seem like too much?) , and I will be back on track to boat in the spring. Last thing, where is the most economical place for fiberglass and resin (& particular type?) And will the CPES be sufficient on the underside of the plywood?
Took the heads off of my 351 yesterday to make sure it had held up well since 2007. Looks perfect. Pulled 6 years of parts and a moves worth of miscellaneous "stuff" out to uncover the skeleton of what I hope will be my running Ts6m Comp by spring. Thinking seriously about using Coosa Bluewater 20 3/4" board instead of wood for my floor. Think I could pull it off with 2 4x8 sheets (pricy at $300 a sheet, but "do it once and do it right"?). Here it is with the stringers glassed in. Attachment 12951
