So I had a brainstorm. Has anyone used one of those suction cup attachments on their waterski to mount a gopro camera. The mount says it will stay on up to 150 mph. I'm just worried that a hard fall will dislodge it
Buy the rear door float kit for it. It's bright orange so you can see it. If you clean the ski with denatured alcohol first, you can use the tape on base as well.
The float says it won't support the suction base ...
Get a foam noodle float and epoxy a Chung to the back door. I sit that with my old gopro and it would float with any oft handles and mounts.
the suction cup on the board is a bad idea. use the surf board sticky mount. even then I would be worried about a mount failure. I had one of my mount debris the outer day brake on me while I was tightening it down. they do fatigue. I'm sure the speed reading it for wind buffer not impact with water at any speed ( not that your going to fall our anything).
I've used the suction cup mount on my wakeboard. I used a small piece of stainless cable and made a tether to attach it to the bindings in case it decided to fall off. It has never fallen off even when I crashed, but I definitely wouldn't trust the suction cup alone.
Yeah that's what I was thinking. I was going to run a piece of thick fishing line through the binding laces then around the camera. How were the pictures. I tried it last week with a chest mount and it was pretty cool.
I got some really cool water spray shots when I faced it behind the board
on my monopod.
https://www.youtube.com/watch?v=MVTy...e_gdata_player
Very cool. What program did you use for the slow mo
Adobe Elements 11. you can get a free trial version.
All, been thinking about the GoPro as a family gift. I don't anything crazy or extreme hi def, just to record us having fun. I've done some searches but wanted to see if there were any recommended sites or tips you guys would like to share.
Thanks in advance
John
GoPro is interesting in that they have the prices "fixed" as it were and the price won't change much if at all between places for the same model. Meaning you can't just go up the road and get a better deal then the current store that you are in. Personally, I am still running the Hero2 and I have all sorts of add-ons for it that I use such as an extended battery pack that allows me almost five hours of run time. I also have almost all of the mounts that are offered and have played around with where I mount it on my boat and myself when I ride. If you are looking for super budget just to get started, I would try and find a Hero2 as the new Hero3s are what everyone wants, myself included. As for the crazy Hi Def recording, all GoPro cameras are able to record in various Hi Def settings. At the end of the day, you won't be disappointed especially if you want to try and improve your form on your ski or just capture family and friends goofing off with the boat having fun.
Just a tip but the Hero 3s are about to get a lot cheaper. They've already started showing up on discount sites. H4 will be out within the next month.
I too have a H2 with everything including Wi-Fi. I would recommend a H3 Black due to its very high frame rates and built in Wi-Fi. H2s and there accessories are only available online. If you want one too video tape family stuff and not videography stuff then I would recommend a cheap camcorder. The field of view is too wide to tape sport games and family events. Also anticipated video editing software and a computer able to push it.
I have the gopro3 silver. I love it. I have a chest mount and the suction. Tried the suction on the ski this weekend didnt ski very hard cause it was rough but I did get some cool shots. The chest mount is pretty cool also. Gives a view looking down the rope. I have usedine a lot since I have gotten it. Cliff diving underwater swimming. I'm a big fan and highly recommend it. I would get the hero 3 though. My photo guy told me the upgrades are noticeable.
Wow, thanks all for the great product overview. I've been using a flip to record most of my runs, but it also requires a free hand from someone on the boat. The GoPro has so many advantages it just make sense to buy it. Tower, ski, chest, helmet, pylon, or other. . there are so many views and mounting advantages and angles to play with. Pretty cool. thanks everyone!
You might run into an issue with mounting it to the tower depending on the circumference of the tubing. My tower tubing is too large for any mount that I currently own though it does work with the ski pylon. Granted my tower is after market and therefore yours might be the same circumference as the pylon in which case it will work.
This (http://www.ebay.com/itm/Billet-Alumi...item3a7f26f2dc) + a regular 1" velcro strap will work on almost any tower or tube. I use mine all the time for all kinds of things. My velcro is 3' long and I can just wrap it around as many times as needed to secure it.
just use a sticky mount. I don't think you will be happy with it though due to its distance and constant moving. The tower is on the end of the pivot point for a boat and has the most movement. If you need to mount it to the actual boat the farther back on it the better. I made a mount that sits over the rear ski pole that works well but I don't use it much. The best mount I have found is with a monopod. It is what is used in all of the cool Gopro videos of the snow skiers and such. Takes some practice and some video editing but I use mine all the time. I highly recommend going with the Black version due to its high frame rate and Wifi. The frame rate allows for ultra smooth, ultra slow motion. I use my wifi with android app for just about every setup to verify viewing area then switch it to the wifi remote. Its the best option available and being built in makes for a super compact setup.
3 spam posts by this new UserID posting above.
That is the most activity for the last 2-3 days on the site. Bummer.
Sent from my iPhone using TapatalkAttachment 19076
Nice video.
