Custom Surf Platform build
I thought I'd post a formal thread on this project.
My buddy "Phathom" (Desi) is doing the work, and together we've been doing lots of planning and measurements. Our objectives have been to get something with a SMOOTH bottom that doesn't have a huge lip that digs into our surf wave. We also wanted something that was as narrow as possible relative to the surf wave without changing the platform bracket location. We chose to add a little length to it to make it more user friendly.
Here's how it's looking so far:
Quote:
Still have to sand down more(possibly) and coat the bottom. It's all cut, sanded and coated on the top. It is measuring 62" at transom, 14.5" deep the brackets, 13 3/4" long angled transition, and a 43" wide platform end that measures about 23 7/8" long transom to platform end all at 7/8" thick.
It's made out of two pieces of plywood sandwiched together, because that's the wood we had laying around. Spray on undercoating to cover it, again because we had it laying around. If we like it, we'll make one out of a single thicker piece of wood, glass in the wood and put some closed cell foam decking pad on it.
My outer brackets were pretty wide, so we did what we could on width as I didn't have much of an interest in moving them or making new ones. (thanks for the welding offers though). I should have to cut off about 1.5" of the extisting outer brackets though. But it's the flat bar before the angle brace comes in, so it shouldn't affect things much. Not sure if we'll have to shim the new platform up or if it'll be thick enough to match the height of the existing as is.
https://lh6.googleusercontent.com/-_...233806_076.jpg
I did a drawing of the dimensions. The platform brackets are in orange. they overlap our platform a tiny bit on the sides, but should we go with a full blown version, it'll be easy enough to chop 1.5" off the ends of the brackets that extend past the angle brace as mentioned above.
https://lh3.googleusercontent.com/-L...Dimensions.jpg
Pictures of the OEM Platform for reference:
https://lh3.googleusercontent.com/-y...812_115954.jpg
https://lh4.googleusercontent.com/-4...812_120019.jpg
How will hdpe hold up to the sun and heat when out of the water?
Ok kewl!! You learn something new every day
The downside to hdpe I believe is that it shrinks quite a bit. In the size of a swim platform, probably doesn't matter though.
Guessing it would also sag more than the standard alternatives.
Tige huh?? Good choice! Lol. Which one is it?
I'm in. Just a thought would line x stick to it?
Quote:
Originally Posted by
trayson
Update. However, I have to buy a whole sheet, which is enough to make two platforms. I think I'm going to wait until I have someone else that wants one to distribute the cost of materials better.
I am in. 10char
