Originally Posted by
cadunkle
Simple solution, first get your truck tuned right. You should not be putting out plumes of dark sooty smoke. You need either less fuel or more air, pick one or a bit of both. Keeping a standard low exhaust you can run yours farther back and exit in front of the rear tire at about 90*. Don't go ridiculous on size, it looks dumb and does not help power. 3" is adequate, 3.5" is plenty, or whatever your downpipe size if that's bigger. Your restriction is at the turbo , making it bigger farther downstream does not help. Maintaining this size will help keep velocity up at the tip even after the gasses have cooled some, with a 90* exit this will blow farther away from the trailer. Alternatively you could do a stack high enough and and exiting at a 45* angle or so behind and to the side. Single stack of a normal (non-ricer) size in corner of bed with heat shield, and won't affect what you can put in the bed too much and will get the exhaust away from your trailer. I don't understand the 5" duals comment, does this engine have compound turbos with 5" downpipes? If not, you're going about the exhaust wrong.
Personally I've been running a straight pipe ending at the back of the cab just inside the frame rail. I put a 38 gal rear tank in and the exhaust interfered so off it came. Eventually I'll get around to extending it and it'll come out at an angle right in front of the rear tire. I don't want to deal with bending large pipe for clearance around my larger tank/axle/spring/etc.. I have not had an issue with the boat getting sooty. The underside of the truck is sooty though, which is my main reason for wanting the exhaust to exit out the side clear of everything. I don't have my pump cranked way up though, so getting into the pump working it hard it'll smoke a little until it's spooled up but then just a haze or very light smoke if any. A bit of smoke while it spools should not gonna cover the boat in soot.
