Trailer repair
So I bought the boat in the end of August last year from the original owner. As you can see he shredded a tire on the fender pretty bad.
http://uploads.tapatalk-cdn.com/2016...8dde9a5a82.jpg
Spent the last weekend on it banging it out and putting a few new welds on and I think it turned out pretty well. Now time for some sanding, priming, and some implement paint.
http://uploads.tapatalk-cdn.com/2016...1a398e04df.jpg
Double axle ftw. That was a hell of a blow out. Nice job, clean off all that rust before you shoot it!
That looks like the boat is sitting a long way back on the trailer. Can you lift the front of the trailer by hand. I pretty much can't lift my trailer. Admittedly that is too much weight over the Towbar but yours looks too rear heavy
Yes, I can lift it by hand. But it is like squatting plates approximately. It is on the original trailer and I pull it all the way up to the bow stop every time. Were the original trailers rear heavy?
Trailer repair
http://uploads.tapatalk-cdn.com/2016...84b0d7d524.jpg
Started priming it up tonight, once I'm finished I will need to sand up a bit before spraying it. Also got some new vinyls made for the registration.
Looks like it is positioned on the trailer good to me, the engine should be right over the axle(s). Nice work!
If u can lift the front easily then I personally think it's to rear heavy. From memory should be about 70-90kg down weight on tow ball. As long as there is some weight on the front then I think your ok.
That appears to be an OEM supra trailer made for that model of boat.
Snug the nose of the boat up to the left and right vertical posts at front of trailer and you are done.
http://uploads.tapatalk-cdn.com/2016...ca20cc79d6.jpg
Got her primed up over the weekend.
Put non skid on top surfaces near the winch hurts like a sob to slip and get a leg caught in between the xmembers. While pulling the boat on the trailer. Will maybe save some serious injury.
http://uploads.tapatalk-cdn.com/2016...dfced3f6dc.jpg
Putting it back together,
http://uploads.tapatalk-cdn.com/2016...10f829c0ba.jpg
With the boat back on it. You can hardly tell that a tire was shredded on the trailer now that it's all panted up.
Looking to add some nonstick pad to the tops, plan to work with gatorstep to get pads made for the trailer. If all goes smoothly I'm thinking about doing the floor in the comp with it.
https://uploads.tapatalk-cdn.com/201...0ce0d124b2.jpg
https://uploads.tapatalk-cdn.com/201...bd13339a62.jpg
Got the swim platform upgraded to a teak. Bought a used one off a crashed boat for $150 bucks and a few hours later it almost looks brand new. It's gonna feel so nice on the feet. Time to get out on the water.
Nice work, love the teak!
