Replying to Topic 'hydraulic wake plate'
no transom reinforcement is required. You simply take off the old plate and replace it with the hydraulic one. Of course, with a few holes added to the transom. I got lucky and picked up a used unit for $400.00. A new system is going to cost around $600 to $800 for the entire package. I do not know what the labor charge would be. I installed it myself. The problem I had was in removing the fuel tank on my 89 comp ts6m. I ended up hooking a comealong from the fuel tank to the ski pole. The fuel tank had been installed with some rubber pieces on the straps that had adhesive on them. No way to pull out the fuel tank by hand. It was not too bad to be a shade tree mechanic project. The other problem will be the location of your pump. I did not have much room to work with so I set it behind the seat and in front of the fuel tank on the port side. I had to reposition the blower motor that is located in that same area to make it work.
See if this helps: reach behind the guage, loosen the trim ring holding it in place, and turn the guage 90 deg clockwise.
Now it is in the same plane as the plate itself. So when the needle is horizontal (at approx 50%) so is your plate, And when the needle is up (near zero%), so is your plate.
I did this a week after getting our '02 SSV and never looked back. Now what would make it perfect Skiers Choice, would be a picture of a side profile boat hull in the guage, like Sanger have.
Hope this helps! Keith.
Turn the guage 90deg clockwise
Please post phone #'s to Bennett. Or, did each of you just call the factory?
Thanks for your help,
Joe Pandak
How much does it cost to go froma manual plate to a Hydraulic one?
