I picked up a 92 Supra ts6m and want to change out the protech ignition with a DUI system.
I took a picture of the engine tag so that I would get the correct kit before I put it away and noticed the firing order on the tag reads 1 1 8 3 7 5 4 8 ? The model is PLD-PR-R12PT. I took a couple pictures knowing I would swap the ignition out, but forgot about the different motor rotations? . It does have the PCM 40a 1.23 to 1 transmission. The boat is not stored here where I live so I can't just step out and hit the starter and see what direction it turns.
I would appreciate if anyone could translate the tag so I know the rotation ( and whether that is looking at the crank from the front or the flywheel from the rear?) and determine what that firing order is? I figured it was standard rotation (CCW left looking at the flywheel) and 1 3 7 2 6 5 4 8 ?
I will try to upload a pic of the tag.
Dave
