Universal Wakeboard Towers.
Ok ladies and gentlemen. I've been searching for about 2 years for a tower for my '87 Marauder. I think I've finally found it. Every other Universal tower I've seen has looked cheap and I've heard horror stories from friends and fellow boaters about their strength and the rattle and noise they make. Now I've been doing some research and I think I've finally found what I'm looking for. Check it out. Let me know what you all think. Its called the Aerial Freeride tower. It is universal and looks OEM.
http://www.aerialwakeboarding.com/Articles.asp?ID=199
Don't know about the other aerial
I had an aerial assault tower on my last boat and it sucked bad. Wobbled side to side bad. Sucked so bad I sold it and bought a supra. Good thing! The set screws had to be tightened twice a day. Had a lot of weight on it with a light bar, a pair of pro 80's, a pair of pro 60's and a bimmini. Really didn't like the way the universal mount worked. There are two 2" round mounts that bolt to the outside of the hull (on the sides). Crownlines have thick glass and I reinforced behind the glass with 1'2" ply. You could still see the side flex. Even got two small stress cracks in the gelcoat(yes I reamed the holes well). The only good things I can say about aerial is they are cheap, look good and they do have good product support. I really don't know about the other towers though. If I were looking for an aftermarket tower I'd look for one that has a larger mounting flange on the sides.
