I just purchased a 2004 Launch SSV. I am happy with everything but the steering. It's extremely tight both ways and harder to turn left. I've read that I need a new steering cable. Any ideas and can I take care of this myself?
Thanks,
Brooke
Thanks,
Brooke
Sounds like the cable . If you are handy you can DYI . First disconnect at the rudder and see if it gets better it might be the rudder packing.
check out the moomba forum how to section there is probably a thread there
I changed mine out last season on my 04 SSV...its an easy DIY. I would definitely recommend pulling up the two floor panels (you will see the gas tank and a run of wires including steering cable) to make it easier. I dont remember the part # but call skidim.com and they can tell you. You can find it cheaper though.
Sent from my SM-G928V using Tapatalk
Pull the floor up (toughest part). There are 4 screws in the corners of each panel (2 panels). Tie string to end of old cable and pull from the steering column. Tie the rope to the new cable, push it hard thru the hole, then use the rope to pull it to the back.
I packed the support tube with grease before putting the rubber caps back on to try to prevent water getting in again.
