1988 Supra Comp Transmission/Help!
Hi All,
Newer member, picked up my first inboard this winter. a 1988 Supra Comp, 351W with the velvet Drive 1:1. Boat is in mint shape, new stringers ect. I picked it up on Saturday, put it in the water on Sunday, was slowly cruising around the lake and the boat was running like a charm. I then noticed that it started to run pretty hot so I shut it off. I had the impeller replaced before I picked the boat up. Thinking they may have put it in backwards.. idk. Another issue I have is that the trans fluid was changed in the fall before winterizing, when I looked in the bilge by the tranny there was red trans fluid down there.. not aton but enough to be worried.. also now the boat will go into neutral, and the throttle will move freely in neutral, but when I push the button in and put it into gear the throttle will not move forward or backwards. Any ideas? There is still plenty of fluid in the tranny, not sure why the throttle will not move while it is in gear.
