LOOSE STEERING 2004 Launch SS DD
Well I worked on my steering on Saturday to try and fix some issues. First, when you would turn fully hard left, it would seem to bind when trying to straighten it out. I noticed that tiller arm was almost straight in line with the cable, so I adjusted the tube and greased the ball pivot and rudder post.
Took it our Sunday and its really fishtailing(wandering). I've read all the threads about the link at the end of the cable to tiller arm connection, and noticed there is some slop there. I am going to dismantle my tilt steering tonight and check for loose bolts, and also check the pinion to rack engagement. The cable moves smoothly in both directions with no binding now. I've noticed from day one, that the steering is loose compared to my 89'. It was smooth and tracked great. Had it 24 years and never a problem.
