sudden transmission noise
Hi all
I have a 91 ts6m with pcm1;23;1 trans.
Been skiing all summer and no problems whatsoever until the other day started boat cold and trans whined for a few seconds then went and was fine all day.Next time started cold on drive and did same thing.Was never there before last 2 cold starts and stops noise after few seconds,almost as if something is getting up to pressure then fine.
As far as i can tell no leaks and fluid clean and works fine all day after initial cold start.
Any ideas if something is on the way out?
Also has anyone got idea of what trans level should be on stick cold as such a pain to check when out on water and also fluid is so clean its really hard to see.
Thanks dave
