Only 1 left!
Only 1 left!
Maybe list on the Moomba board too. I just bought off of eBay not thinking to check here first. Probably from your friend.
One still available.
Bump
Still available
One left!
any of these left? i would be interested
Yes. One left.
Can anyone tell me what their experience is with this one in a 22SSV? I was under the impression that they were made more for the 24SSV...
I have it in my Launch SSV from 2001, which is basically the same as the 22SSV.
It works great.
Ideally it would be a couple inches narrower and a few inches longer to fit the compartment perfectly, but I would still say it gets at least 80 % full and it is hard to find anything else that would fit there close to a 1000 lbs.
I am using that and 2 x 750 lbs in the back. The tailored 565 lbs or whatever they were would give the same result I imagine as the 750's are also too large for the compartments and the dimensions of the tailored ones seem perfect.
I would definitely go for it, but if you are using stock hippo-system and the original pump for empty through a through-hull in the back of the boat expect long fill times and really long empty times... :)
