Hi I'm looking to upgrade my 02 SSV with 1100Lbs in the rear lockers. Just curious if anyone has done the same? Do they fill all the way up?
Any response would be appreciated.
Had an 01, 750's don't even fill all the way up. Realistically the 565's (or whatever the specific fit ones are) are the right size.
Ok I upgraded to those 10 years ago and I would say they fill the locker. I haven't taken out the board that would give a little more room towards the front of locker. which I thought may give more room to add the bigger bag.
Ya you can't even fill the 750 so the 1100 would be useless in the rear. The best option would be to upgrade to the 1180 up front if you haven't already and add the stock 650 sitting in front of the rear bench seat. People can use it as a footrest rest and it should give you all the weight that boat needs. + some depending on the amount of passengers.
I got some 600 sumo bags in back that fit nicely wake makers will get you hooked up with what you need!
