isurf: We have the 1100lbs rear bag full with about 400lbs on top of it, and the front 1100lbs bag full as well.
ScottnAz: If running 1100 in the bow, I'd shoot for closer to 1500 on the surf side rear of the boat.
fman: Might want to also not fill your front bag with as much weight, try 50-75% this will drive your rear corner deeper
I'm starting to see a theme. Sounds like whatever the setup, y'all are striving for about 2/3 of your rear weight up front. Makes sense. I found the weight on the non surfside helped when it was choppy. No it was not choppy in the pics above but the wind was up and causing problems a couple other days.
ScottnAz, i have the same goal. I'd like to not assign seats when i have a crew, have enough weight that it doesnt matter where they sit. With that said I'd also like it hidden and to be the biggest wake they have seen :) If you start working on that setup, we will soon see if you have it "figured out" or if you just have soo much weight you cant be wrong. haha :)
Scott - NICE wave on P1 there!
