Amp wiring question - does size matter?
Just picked up a used ‘07 24SSV with stock speakers and sub but the previous owner had installed 2 HT4 amps. They are running what looks like 10awg power and ground wires to the amps and it calls for 4awg.
My question is wondering if I truly need to upgrade and how soon? The wiring mess leaves a lot to be desired but fixed 75% of it as I upgraded the factory headinit to a new Kenwood Bluetooth model today.
Sure it does. That sounds right on the size 4 from the battery to the unit.
I assume the smaller wire and a big power draw could potentially cause wire to melt, poor performance, or damage to the amp b/c of not enough power.
How long do you think the boat was running with smaller wire?
Do you have an in-line fuse?
