It should have been a stainless steel bolt the housing is brass corrosion should not have been a factor. Use a little heat and vice grips to get the old bolt out.
So, got the boat out on the water today. A couple concerns....
1) boat vibrates quite a bit, It could be bc I'm not used to the older style boats, but how much it "too much" and what could be caused? (Its only while underway)
2) upon inspecting the engine compartment i did find a little bit of water coming in from the drive shaft that goes thru the hull... (worn bearing? Possible cause for vibration?) Nothing too serious other than I wouldn't feel comfortable leaving boat in water overnight.
3) boat seemed to run very hot (see photo) and oil pressure seems high... after about 20 mins of runtime. Not sure why it's so high... possible thermostat bad? Not opening? Any help is appreciated. https://uploads.tapatalk-cdn.com/202...d12f05d401.jpg
Sent from my SM-N975U using Tapatalk
Update, replaced thermostat. Pulled old one and placed in boiling water. Never opened. I'm assuming its bad... replaced with new. (180*) hopefully it cools down, now my oil pressure in another thing.
Lookup how to align the propshaft. It should be done every couple of years. It takes about 30 mins with some feeler gauges. If its really out of whack, maybe an hour tops...
Also, dumb question but is the prop dine and dent free? The smallest ding can make a difference.
As for the leaks, small drips while underway are normal. When stopped it should not drip. I can't remember off the top of my head but somewhere around 1 drip every 5 to 10 seconds is normal. It's better to have more drips than less, as too little cooling on the packing glands will score the shaft and will require propshaft replacement.
The packing around the propshaft needs to be cooled by water when running. You can tighten the nut to slow the leakage. If its tight but youre still getting too much water in, replace the packing.
Next on the to-do list
The temperature. Is this a normal temp for the motor to be at? At what point should I be worried? I put a 180 degree thermostat in there. But not sure if that's good or not. It climbs slowly up to about that area. And stays.
2nd photo is the gelcoat after 1full day of buffing and waxing. Not perfect but way better than it used to be.https://uploads.tapatalk-cdn.com/202...7e688bc375.jpghttps://uploads.tapatalk-cdn.com/202...cb5184fd8c.jpg
My Comp stays at 160 in the summer time. If the water is cooler it will sit around 150.
Video on aligning shaft: https://www.youtube.com/watch?v=5UqniaiggKA. The vibration is either from this or from the prop being banged up. It doesn't take much of a ding on the prop to make things vibrate.
Blog description of how to fix leaking at the stuffing box: https://marinehowto.com/re-packing-a...-stuffing-box/. These boats are designed to leak at the stuffing box. There is a wax string that helps seal the stuffing box. It dries out and needs replaced. Skidim has the string or you could replace with Goretex: https://www.skidim.com/prodinfo.asp?number=GFO316X24. The stuffing box needs adjusted every now and again.
On temp, check your hoses and see if any are soft and might be collapsing under low pressure. That impeller looked pretty rough. Maybe the hoses also look a bit rough. Hopefully you don't have chunks of the impeller stuck somewhere. Maybe a 160 thermostat will help.
That gel coat wax is looking sharp!
