Originally Posted by
Jetlink
I wouldn't 5200 the exhaust, 4200 is more than enough for the job. As for the hesitation, a proper tune-up should help you there. Check the timing, check the plugs and replace the fuel filter and while you do that, drain the tank and start fresh. That should really help narrow it down. You don't have to do these all at once either, maybe one at a time and then try it out again to see if that fixed the problem. I would wait on the prop until the very end because getting the engine dialed in first will help you if/when you go to select a new prop.
