Looking for information on ignition systems
My 86 TS6M has been having issues ever since installing a new Mallory E-Spark module. My original electronic ignition module failed and I replaced it with the Mallory. Ever since, when cold my boat will start up fine but after cruising around for 15-20 minutes and shutting it down, it will not restart. What happens is the ignition coil heats up and I loose spark until it cools off again. I have tried different coils, checked over wiring, adding/removing ballast resistors, etc. I'm thinking about just starting over and getting a whole new distributor with electronic ignition and hopefully resolving the issue. Does anyone have any recommendations on a good reliable set-up that will work with my 351w along with cost and where to purchase? I'm looking to get back into business with the best 'bang for the buck' solution.
