Running hot on one side???
I’ve got an 86’ Sunsport with the 350 Windsor. Just rebuilt the tranny so I’m finally ready to get this rebuild on the water but now the I have 3 more issues:
1. The right side / starboard side is producing a good amount of black soot that is staining the back of the boat
2. The right side / starboard side is running much hotter than port-side. Haven’t shot it with a laser but it is very much noticeable by touch.
3. The engine will sputter out and die after a few minutes.
Once I get the bell housing and tranny back in I’m going to start working over the engine. I’m curious what steps I should take for trouble shooting? So far I have (1) tuning the carb and (2) doing a dry and wet compression check. Any other suggestions?
Quote:
Originally Posted by
SquamInboards
Hey I was just browsing here and saw this thread. I have to chime in and say I chased the same issue on my boat for more than two....
After rebuilding the carb it’s idling and running seemingly well, however, the temperatures of the manifolds are still significantly different and I found ANOTHER ISSUE...
The good news: I found that I’m pushing an aggressive amount of water, so I should be good there. Each side is pushing an even amount of water.
The bad news: took it out and found that it takes forever to get to max speed which is currently only 28mph. So either the engine has no power under load or I need to get a different prop, but I don’t think it’s the prop...
I removed the left hand side riser to find what appears to be an oil trial down the manifold to cylinder 7.
https://uploads.tapatalk-cdn.com/201...81d0806fdf.jpg
