Originally Posted by
lively
Well if it was me , I would ohm the pump motors out to see what they read and then find why the circuit is feeding so many amps . Let me know because it's almost either there is blockage or the relay is not shutting off when it's satisfied for start up . Idk I see why they use the low press pump it's just a little feeder from the tank . But to blow a fuse while both are on , high Amps or blockage or little of both maybe . With out a meter or some ohms readings idk . Let me know what you find !
