Originally Posted by
Cornado
Thanks folks. I don't have a volt meter, something I will need to add soon. The other accessories were on so I didn't think it was the battery. I decided to try charging the battery and that did the trick. I can spin the alternator by hand so belt needs to be tightened or alternator needs to be replaced or both.
@michael Hunter I am not sure actually on motor size ( i know right) I believe the 454 by other pictures I have seen here but the tag doesn't say it or I don't know where to look.
the starter is new, the old one is still in the cubby upfront under the passenger side storage compartment.
I did check the neutral switch at the stick but not on the transmission end.
We did get it running and ran it on the lake the next day. It still didn't want to hit on the turn of the key every time. Sometimes it would take several turns of the key to get it to turn over.
Thank you everyone. Again I have lots to learn.
