Ballast Pumps on 2012 242
I had my old 750 lbs Fly High bags left from my old boat, and with a quick call to Wakemakers.com, I was able to get all the extra fittings needed to swap these out for the factory 400lb bags. This swap took about 3 minutes per side as I didn't have to get the existing fittings out of the old bags. This upgrade made a huge difference in the surf wake.
However, when I went to reprogram the timers in VISON, I thought I'd verify that the timing on the Center bag & belly tank.
This is when I noticed there was nothing happening with the center tank. I am sure this is something the dealer would fix under warranty, but I don't want the hassle or the downtime of taking it over there if it is an easy fix. I couldn't follow the piping back to the pump as it went under the floor. I checked the fuse, and it was fine as there is only one fuse for the 3 tanks. Honestly, I am not sure what the factory setup is like: one ballast puppy or three separate pumps.
My guess is the impellar on the pump is just frozen and if I can loosen the housing, it will break free. However this is a blind guess since I don't know the pump setup.
Can someone point me in the direction of the center pump or give me any insight in to what to look at?
Any help would be greatly appreciated.
-ST
