2010 Launch 22 Worlds won't start and no display after starting once this year
Hello,
We have a 2010 Launch 22 Worlds that won't start. We had it in the driveway yesterday and got it started after cleaning with the radio on for a few hours (and the key in run vice to the left new Supra owner mistake). I turned the boat off after a minute to check for water flow and then the boat won't start again. The display won't power on either. We put the batteries on a charger overnight and checked all the fuses under the dash, reset the circuit breaker by the batteries and checked for loose grounds under the dash- no luck. It seems like we have a bad ground somewhere but don't understand why the boat started right up then now won't start and the dash won't turn on? Batteries are from 6/2018 and no corrosion on the terminals although we were hard on them with the stereo on with the key in the run position. We tried to jump the batteries as well, no luck.
Any ideas? The dealer can't look at the boat until early June!
Thanks!
