Adding a sub to '05 21v need some help with enclosure
So I purchased a second amp and sub to add as a winter project to my boat which did not have a sub in it before. I was given a lot of help by the place I purchased the equipment from as far as what kind and size enclosure to use but am having a bit of a problem. When I took the kick plate down under the drivers area, I have a ton of room for the correct enclosure except for the wires coming up through the floor. Has anyone added a custom enclosure to this boat that can give me some info on what you did. What I was thinking is if I cut a slit in the floor that I could slide the wires down to get them out of the way. Any information would be greatly appreciated.
