Brand new perfect pass install
I got my upgraded stargazer perfect pass today and got it all installed. I haven’t had the boat on the water yet as everything is still going back together since the rebuild.
It’s the drive by wire version that does not use a servo motor any more. I inserted the wires in the plug at the engine harness, connected the ground right on the same bolt the main battery ground attaches to the engine. Battery is charged enough to start the boat.
When I power up the perfect pass, just the backlight on the screen comes on and it blinks. I do not get an audible beep from it either. I can hear a clicking inside the main processor box for the perfect pass.
I read over the manual and looked at their troubleshooting page, the only thing I’m coming up with is low voltage. I have 12.5 volts where the perfect pass positive connection is. Once I turn the key voltage drops to 9.5v across the buss bars under the dash. (If I pull the fuse for PP the voltage goes back up to 12.5) I went as far as connecting the positive for the perfect pass right to the positive buss under the dash and I still get the same thing.
Please help!
