Originally Posted by
87SunSportMikeyD
Fman I would also be happy to lend tips anytime. The trick is truly in the progressive edge technique. Neither a big cut nor lots of speed are necessary. The trick is to load the line by leaning back and digging your edge in. Even starting less than 10' outside the wake I can clear it.
When you edge out for your setup, pause 3seconds before cutting back in to let slack out of rope. Don't initiate your turn by turning your board. Lean back and set your edge with your weight a little more on your back foot. Try to arch your upper back and try to stick your chest out. This holds your stance in the proper position and really lets you lean away from the boat. Your board should still be at about a 45 degree angle to the path of the boat. No super-hard cut is needed (we'll add that back in later). Start out with a mellow cut and built as you get near the wake. But you have to have a good solid edge set throughout the cut.
When you hit the wake, pull the handle in and dont try to bounce or jump just straighten your legs and brace for the pop. Keep the handle in near your waist while you're in the air.
