Depth Finder
I'm thinking about adding one of these to my '88 comp. we just bought a house with lake access to a damed up river. With many low spots in the lake I want a way to monitor the depth a little easier.
Has anyone used one of these?
http://m.overtons.com/modperl/produc...ls.cgi?i=74431
I installed a similar unit in my 89 Sunsport where the clock was in 89 still works great. I like the water temp feature on that one.
http://i303.photobucket.com/albums/n...ps7d242593.jpg
http://i303.photobucket.com/albums/n...ps782f352a.jpg
It's ordered, should be here next week. The water temp feature was the reason I went with faria over the hummingbird.
In 1990 when I bought it there was not that many choices.
Depth Finder
Do you know of a place to get the center logo for the steering wheel? I just have a cheap black foam one and yours looks real nice.
http://uploads.tapatalk-cdn.com/2016...2e503205ae.jpg
It's here, hopefully can get it installed before next weekend.
Got deck mounted, now have to work on mounting the transmitters. Two temperature sensors and one transmitter.
http://uploads.tapatalk-cdn.com/2016...e74e7b7072.jpg
If you haven't mounted the transducers yet, I would suggest using silicon or some temporary adhesive in different areas to make sure it reads at all speeds you want (not interfered with by cavitation/water flow) before drilling holes in the transom. Also put silicon/4200 on the screw threads to keep water out and tight.
