Fuel Filter (INSIDE PUMP?)
on a different blog a problem with the with the same Inmar motor, I was told that there is a 40 micron filter on the inlet side of the fuel pump. It was said to remove the rubber fuel line in at the bottom of the pump and inside the metal barbed nipple there is a filter. I was told to extract and clean the filter. I have to "assume the position" to try to get to the bottom of the pump but I am not sure if this filter even exists. here is a URL with some picts that I found on line. Has anybody done this?
https://www.themalibucrew.com/index....ump-read-this/
