Has Anyone Seen error Code as follows: DTC 91: FP low voltage?
under correction action there is nothing. Any ideas?
I don't know what the code means, but if I were to guess, I'd think it has something to do with fuel pressure based on the "FP".
Is the boat still running okay? What kind of problems if not.
edit-
Based on this, FP definitely stands for fuel pressure. Low voltage may mean your pump isn't pumping correctly and you may be running lean.
https://www.bakesonline.com/images/M...manualv1.2.pdf
Boat is running fine now. Was very low on gas at time and did not want to start, then after about 20 minutes it did and ran fine. I thought same thing, but was not sure what that would have to do with low voltage? Thanks for response.
