Boat lights flickering
My navigation lights on my 89 Sunsport just flicker on and off again when I pull the switch out.
They will only actually stay lit if the pull switch in held in a specific position m somewhere between true off and on.
Would this be an indication of a bad swtich...or an issue in the wiring.
I will say it only effect the bow running lights. The stern pole light remains lit when the switch is pulled completely.
I have replace the stern light with an led unit...so I know that is not it. So I am left wondering do I get a new switch or run new wire.
Sounds like the switch . you can run a jumper wire to confirm.
