05 21V Ballast System Upgrade - Need advice
I'm looking to upgrade the ballast system (pumps and plumbing) in my 2005 21V. Currently, I am planning on going with 4 Jabsco pumps (one for filling accessory bags in the boat), adding three through hull mushrooms (one for each pump) below the water line, and using the current drain plumbing as the vent lines with check valves added. Any advice for me? Should I get a 'Super Sac 'R kit? Is it worth it? Also, is it difficult to run 1" tubing to the front bag?
From several days of research and reading on forums, Wakemakers.com seems to be the best place to get the supplies (and in the two calls I have made to them to ask questions, they have been great to deal with.)
While I am ordering, I am also going to be ordering an ACME prop....1443. Any reason I should consider another one? I primarily surf and wakeboard.
Thanks!
