2018 SL450 Ballast/Bilge Question
I have a 2018 SL450, recently when I am filling the ballast it seems like the bilge is kicking on after I fill the ballast. When I look in the engine compartment and where the center drain plug is there is no water but the bilge seems to be dumping a lot out. The 2018 has a sub-ballast system...is it possible that this is somehow leaking and it is triggering the bilge. This only happens after I fill the ballast, and just started happening recently. Thanks in advance for any help.
My guess is one of your subfloor ballast bag fittings or hoses are leaking.
I would imagine it’s a coveted warranty item and you should still be under factory warranty.
