3 Attachment(s)
Spark plug boot trick/TEMPO oil pump
I just changed my oil today in my '08 22V and wanted to pass along a great little setup that makes changing your oil even easier, with no need to run the extended oil drain line out the rear transom drain plug (this is how I used to do it).
Use a sparkplug boot and attach to the end of the plastic tubing you use to attach to the drain outlet on the oil drain line. Then the other end will compress right on the end of the drain line, its that simple and easy. All you need to do is remove the cap off the drain line and attach the spark plug boot and your good to go.
See attached pictures for better reference. Some of you might already be doing this, hopefully it will help a few out to cut down on oil change time.
BTW, the TEMPO pump I used for the first time today and it rocks, it has great suction for the engine and trans oil change with multiple size different tubes, a must have for anyone without one!
