Starting engine that’s been sitting for 1 1/2 years
Hi all, I have a 1990 Sunsport with the PCM 351 Windsor engine. It’s hasn’t been run for a while. Here’s what I plan to do prior to trying to start it. The engine was properly winterized prior to it sitting.
1. Replace engine oil.
2. Remove and replace spark plugs.
3. Spray fogging oil in each cylinder.
4. Remove old gas and replace with fresh gas.
5. Replace impellar in coolant pump.
I’d be interesting to hear what else you recommend. It’s a carbed engine. Should I remove and clean the carb? Should I try to turn the engine over manually before trying with starter? If so, how’s this done? Any other advice? Thanks in advance.
