Thankssss for that issue
I have the same problem
Big has everything to do with it when you don't have enough channels to support the amount of speakers silly.. wow...
Big is such a technical word for you :p
Seems to be for you, that's for sure...
Are you seriously for real? You knock the dust off a 6 month old thread to debate the word "big"? The lack of amp channels was established 11 days prior to your original "big" post. silly :rolleyes: If you go back and read, you should be able to realize, that my post using the word "big" was in response to the OP's post, in which he asked if his amp was not big enough.
The lack of amp channels was never "established" before my post if you read correctly, "silly". You only asked questions and gave no advice. Twist how you want bud.. just pointing out that "big" does have something to do with it if you look at it as a channel issue and not a power issue. Because face it, a 4 channel couldn't run all that equipment so it has to be not enough channels related to start. His definition of big was never established as I responded right after his first "big" question, then you after me.
Sorry my post wasn't in your time frame, didn't know there was one. :cool:
