Gravity III Ballast Issues
I could go a little further digging on the boat on my own. but I always like throwing out the issue in case someone else can save me headache and time. I have a relatively new to me 2011 Supra Launch 242. It has the pump only Gravity III Ballast system. My Front (Center) bag doesn't seem to want to work - although it worked one time and I almost couldn't get it shut off. I found the pumps as I intend to replace the impellers. I swapped plugs on the pumps and I know that the center/front pump is "operational" - as it growls when it switched on. It doesn't seem to want to switch on when everything is plugged in where it is supposed to be. This tells me I have a connection, fuse, or wiring issue. One curious thing is that when I switch on the front ballast switch (fill or empty), it looks like both the light for fill and empty are on simultaneously.
Thoughts on what to check next... I haven't looked at fuses or wiring yet, but the two rear bags seem to be working, albeit, slowly and from zero, they don't fill to full even though the SupraVision display says they are at 100.
Thanks in advance.
Brad
