Originally Posted by
ATXts6m
Hi there, you mentioned something about converting to electronic ignition. I just bought an '87 ts6m with the PCM Ford 351 motor, do you have any brand or package suggestions for that setup? The motor also has a Holly carb that at this time needs rebuilding as it doesn't run right. I bought from the 2nd owner, and he knows the 1st owner and thinks that the 1st owner replaced the carb to "upgrade" or get more power, which having owned several inboard ski boats I know that won't aid in top speed. Frankly, I think the carb could even be factory stock, BUT, if it were yours, would you invest in changing to a marine EFI conversion, and if so is there a clear choice for that? Or just stick with a carb and rebuild and maintain? Thx much, Michael
