There's this one too.
http://clarksville.craigslist.org/boa/3873966835.html
I'm curious... These are still foamed though have composite stringers and floor. So nothing will rot, but foam can still be saturated and hold a lot of water. This would at least hold a lot of weight and possibly cause delamination or other damage from the water freezing in winter. So on a composite boat that has been used hard and put away wet, with no cover like this one, might one still need to remove the floor and remove all the wet foam and inspect the structure?
I work for high-test whiskey. Crown Royal Special Reserve to be exact. :D
One in Clarksville is also about 1.5 hours from me.
Take a look at Richmond Craigslists. There's a 99 Launch that looks good. Richmond is not too far from Lake Anna. Judging from the ad, the boat is at LKA. He wants 15k. By the time you add the tower to this one, you may be close in price, but the Launch also have built in ballast.
This is the only launch showing, is this it?
http://richmond.craigslist.org/boa/3842762922.html
If So it's been sold for over a week.
No doubt at that price with a brand new PP stargazer system.
Alright folks....2000 launch...has a 310hp carburated engine, hydraulic wake plate, factory ballist...under powered?
