Results 1 to 9 of 9
    Aug 2010
    Feeding Hills, Massachusetts
    Default Motor Mounting alternatives
    I am prepping for a full stringer replacement and I am looking for alternatives to wood screws into the wooden motor mounts. I am thinking of a threaded insert with washers welded to the sides then epoxying this into the wooden mount???? The washers would help keep the insert from spinning.
    What are some other techniques people have tried? Good and bad
    Any feedback is welcome.
    Thanks,
    Fran
    Feb 2009
    Edmond, OK
    What is your concern with the wood lag screws?
    Aug 2010
    Big vibrating engine and wood screw don't seem to be a good mix, I would prefer to change to a bolt and nut??
    Feb 2009
    Edmond, OK
    I see. Well, they have worked well on most boats for years. I know Nautique did aluminum cradles the motor mounts connected to, but the cradle was still lag screwed into the stringers. With 2-3 lag screws per mount, especially with some 5200 on them, I doubt it is much to worry about.
    Jul 2011
    i am going to use a through bolt set up on mine (except for the top they will still be lags)
    Aug 2010
    NJ
    Off shore mounts or similar. Make plates for inside and outside the stringers and through bolt them with epoxy/sealant through the holes to keep things dry. Use nylocks and loctite. The plates on each side spread the load and add clamping force. Bolt your engine to a bracket off the inner plate. Stringer placement and width can be an issue but I'd be looking at entirely different motor mounts for that portion, things designed for go-fasts or jet boats. Would be a good upgrade, though not entirely necessary unless you're adding a fair amount of power and doing straight arm launches all the time.
    Aug 2010
    Default Thanks
    Thanks for the input, I hope to add to the longevity of the motor mounts. I will take plenty of pics.
    Fran
    May 2009
    Back to Dallas!
    Thats a good idea for the side mounts. Hmm...
    89' Comp rebuild thread:
    89' Comp Mod's and fun pic's:
    May 2009
    syracuse Indiana
    You can glass in aluminum plates, basically1/2" aluminum plates utop the stringers, these are then glassed over. Remember to adjust for the height differance. Then, drill through glass and aluminum and helicoil the aluminum for a fine thread mounting bolt. This was how the early Mastercrafts were structured, they still might be. Al
    Supra Beast
    Custom 496 MPI HO 425 hp
    Custom Teak floor
